body repair front sway anti roll bar |
JFG |
Dec 4 2017, 02:24 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I took off the passenger side anti roll bar fittings to replace bushes in the link and assess the rest. I found play in the long cylindrical bush (pictured with collar/bracket) so i took this off. When i removed it i found cracks and broken off metal chunks.
One of the u bolts fits above the box section and the other somehow fits through the inside of the box section. I would like to weld a support plate inside so that any extra material is npt affecting the seating of the triangular bracket in the inner fender wall. 1 problem i see is how do i get the u bolt back through the box section without cutting it open? I know if i weld inside i'll have to cut the box section open anyway but there was no previous cut and weld on that spot. What is the best way to repair this section? |
toolguy |
Dec 4 2017, 04:41 PM
That is what happens when you don't have the welded in factory reinforcement plat on the inner side. . Even with a plate, I've ripped the body when using stiffer bars and autocrossing the car. . The sway bar places an extreme amount of force on some really thin sheet metal.
VaccaRabite |
Dec 4 2017, 05:07 PM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The rust isnt helping either.
Cut a patch, weld it in. Redrill for the sway bar, and consider making a brace for the metal to beef it up a tad. Zach |
914werke |
Dec 4 2017, 05:31 PM
"I got blisters on me fingers" Group: Members Posts: 10,041 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
That is what happens when you don't have the welded in factory reinforcement plat on the inner side. Do you mean the Wheel well? If you meant the tank cavity side, Sorry but there is no such part (IMG:style_emoticons/default/dry.gif) |
914forme |
Dec 4 2017, 05:45 PM
Add one of these from Maddog, what you ned is at the top of the page.
76-914 |
Dec 4 2017, 06:31 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Thx for posting that. I'm going to get a pair of those. (IMG:style_emoticons/default/beerchug.gif) |
PlaysWithCars |
Dec 4 2017, 09:35 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
That seems like overkill unless you are really going to push it hard and frequently. I've used a welded in triangular backing plate on two cars now, both seeing regular autocross duty, with no issues.
toolguy |
Dec 4 2017, 10:12 PM
That is what happens when you don't have the welded in factory reinforcement plat on the inner side. Do you mean the Wheel well? If you meant the tank cavity side, Sorry but there is no such part (IMG:style_emoticons/default/dry.gif) The Factory Parts Manual lists the inner reinforcement and it's been on all my 914 and early 911 cars that were factory equipped with sway bars. Not to be confused with the actual bar bearing retainer which is listed with the suspension / sway bar. Factory Parts manual section 8-2 part #9 914-502-031-12 Sorry for the blurry picture but you can see the part for the inner side of fender. Attached image(s) |
cary |
Dec 4 2017, 11:54 PM
Here's what we put on Doug's car.
Outside : https://www.elephantracing.com/porsche/911/...ts-accessories/ Inside : https://www.elephantracing.com/porsche/914/...ar-accessories/ Sway Bar Backer Plate http://www.914world.com/bbs2/index.php?s=&...t&p=2487933 |
Front yard mechanic |
Dec 5 2017, 10:16 AM
Senior Member Group: Members Posts: 1,157 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Parts squeaky
76-914 |
Dec 5 2017, 03:18 PM
That seems like overkill unless you are really going to push it hard and frequently. I've used a welded in triangular backing plate on two cars now, both seeing regular autocross duty, with no issues. Sounds reasonable but at this age I look at it like insurance and some peace of mind. (IMG:style_emoticons/default/beerchug.gif) |
914forme |
Dec 5 2017, 04:31 PM
That seems like overkill unless you are really going to push it hard and frequently. I've used a welded in triangular backing plate on two cars now, both seeing regular autocross duty, with no issues. Not over kill in a damaged section. Can also be installed completely on the outside, and you do not have to even get into the lower area if you don't want. Cut down or what ever, just covers his back and then some. If your doing the triangle mounts and welding them I'd go with Brad Mayer's 914 Limited mounts. They have an inner and outer pieces and can be welded in just fine, and also do not effect the inner stiffener / passage. Each their own, just providing solutions to a problem. (IMG:style_emoticons/default/confused24.gif) |
Dec 5 2017, 05:10 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
That seems like overkill unless you are really going to push it hard and frequently. I've used a welded in triangular backing plate on two cars now, both seeing regular autocross duty, with no issues. Not over kill in a damaged section. Can also be installed completely on the outside, and you do not have to even get into the lower area if you don't want. Cut down or what ever, just covers his back and then some. If your doing the triangle mounts and welding them I'd go with Brad Mayer's 914 Limited mounts. They have an inner and outer pieces and can be welded in just fine, and also do not effect the inner stiffener / passage. Each their own, just providing solutions to a problem. (IMG:style_emoticons/default/confused24.gif) I keep meaning to order a couple sets of Brad's mounts. Great solution. thanks for the reminder |
JFG |
Dec 11 2017, 01:07 PM
This was the state of the passenger side as of just now (IMG:style_emoticons/default/headbang.gif)
If you're not sure about yours i recommend a quick check by removing one of the brackets or both. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:07 AM |
