OT: trickle charger recommendation, I need an inexpensive trickle/float charger |
914 RZ-1 |
Dec 4 2017, 03:23 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
My car will be sitting for awhile as I ready it to get painted. I'd like to keep the battery charged. I've been starting it up and letting it run for a few minutes every week or so, but I'm thinking this is not effective. It does get the parts moving, though!
The Harbor Freight charger is a POS, according to a reviewer who states he is an electrical engineer and he gave a long explanation to prove why the charger is not really all that good. What are my options for an inexpensive float/trickle charger? |
burton73 |
Dec 4 2017, 03:57 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have a few of these around. I just ordered a different unit from Amazion for 20 and I have not tried it but these work great and I have had them for over 10 years on Porsche
cars Bob B |
burton73 |
Dec 4 2017, 03:59 PM
These are tough too. This one pictured is on my forklift and has hit the ground a few times and still works great.
Bob B |
ValcoOscar |
Dec 4 2017, 04:04 PM
Garage Life Group: Members Posts: 2,380 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
Deltran chargers are a way to go...I use various models on my forklifts, work trucks, tractor and all my cars at home... Oscar |
wes |
Dec 4 2017, 04:26 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I just bought a newer version offered at Costco on sale starting the 17th November though not sure how long the sale last.
brownaar |
Dec 4 2017, 05:16 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Chris914n6 |
Dec 4 2017, 06:54 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I've used one of these for a few years. Broke the case on the first one pulling it out of the outlet just under 90 days then it died. Got it replaced for free.
12 Volt Deluxe Battery Maintainer and Float Charger |
Coondog |
Dec 4 2017, 07:28 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Not cheap but charges everything
Dec 4 2017, 07:39 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ve been very happy with the battery tender jr. $25 at flaps. Not a quick charger but very easy to use and check status.
cary |
Dec 4 2017, 08:07 PM
KELTY360 |
Dec 4 2017, 08:15 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Just get a battery disconnect that fits on the terminal and make sure the battery is disconnected when you're not using it. Battery will last indefinitely without a drain on it.
914 RZ-1 |
Dec 4 2017, 08:45 PM
Just get a battery disconnect that fits on the terminal and make sure the battery is disconnected when you're not using it. Battery will last indefinitely without a drain on it. I like the sound of this! Can you send me a link that has a picture of what you're talking about? When I searched for battery disconnectors I got what appear to be switches for in the car. It sounds like you're suggesting something that just goes on the battery. A picture would be helpful. Thanks for the suggestion. |
thelogo |
Dec 4 2017, 09:45 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
KELTY360 |
Dec 4 2017, 10:12 PM
Just get a battery disconnect that fits on the terminal and make sure the battery is disconnected when you're not using it. Battery will last indefinitely without a drain on it. I like the sound of this! Can you send me a link that has a picture of what you're talking about? When I searched for battery disconnectors I got what appear to be switches for in the car. It sounds like you're suggesting something that just goes on the battery. A picture would be helpful. Thanks for the suggestion. This is what you want. Connect to the negative terminal and all you have to do is turn the knob to connect/disconnect. Battery Disconnect |
theer |
Dec 5 2017, 08:54 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
works like a charm. Less than $10 (probably less than $5) at any auto parts store. |
914 RZ-1 |
Dec 5 2017, 10:45 AM
@KELTY360:
Thanks, I'll try this first. I think I will make whole new negative battery wire assembly. |
914 RZ-1 |
Dec 5 2017, 10:50 AM
While I'm going to try the battery switch idea, I'd still like to get a float charger.
What is the difference between these two: Battery Tender Jr 750mA (#021-0123) $40 Battery Tender Plus High Efficiency 1.25A (#022-0185G-DL-WH) $70 Is it just the amperage? They both appear to have similar features, just different amps. I'm leaning toward the $40 one. One poster said he uses it and it works fine, others use the other ones. |
Mueller |
Dec 5 2017, 12:01 PM
Dec 5 2017, 01:01 PM
While I'm going to try the battery switch idea, I'd still like to get a float charger. What is the difference between these two: Battery Tender Jr 750mA (#021-0123) $40 Battery Tender Plus High Efficiency 1.25A (#022-0185G-DL-WH) $70 Is it just the amperage? They both appear to have similar features, just different amps. I'm leaning toward the $40 one. One poster said he uses it and it works fine, others use the other ones. The jr is very small. It’s just the charger that plugs into the wall and the cables. It works well but takes a couple days to charge a mostly dead battery. |
burton73 |
Dec 5 2017, 01:52 PM
While I'm going to try the battery switch idea, I'd still like to get a float charger. What is the difference between these two: Battery Tender Jr 750mA (#021-0123) $40 Battery Tender Plus High Efficiency 1.25A (#022-0185G-DL-WH) $70 Is it just the amperage? They both appear to have similar features, just different amps. I'm leaning toward the $40 one. One poster said he uses it and it works fine, others use the other ones. The jr is very small. It’s just the charger that plugs into the wall and the cables. It works well but takes a couple days to charge a mostly dead battery. Even the reg one would not charge the 10 month old battery on my 911 Carerra when it would not start my car. Had to put the battery on a reg charger for 24 hours and then it topped it off. |
Lo-Fi Version | Time is now: 4th May 2024 - 07:13 AM |
