L Jet issue, Fuel pump not on, injectors not firing |
koozy |
Dec 5 2017, 01:52 PM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
A friend has a problem. 74 with 1.8 L Jet. Worked before removal of FI and rebuild of engine. Put the FI back on with no changes and the fuel pump won't turn on and we get no firing ofthe fuel injectors. I have no experience with L Jet. What to look at first and what fires the fuel injectors?
Thanx in advance for your help, Mike |
timothy_nd28 |
Dec 5 2017, 02:02 PM
Double check and make sure the resistor pack is plugged back in, and also check that the connector on the air flow meter is indeed on.
timothy_nd28 |
Dec 5 2017, 02:04 PM
Also, the single white wire from the ECU needs to be plugged onto the (-) terminal of the ignition coil. The engine will not even attempt to run with that wire off.
Dec 5 2017, 02:32 PM
If the fuel pump doesn't run, there's a good chance that nothing in the system is getting power. Check the dual relay that hangs off the battery tray.
--DD |
Mueller |
Dec 5 2017, 02:36 PM
Quick check:
With key on you should be able to push the air flap open and the pump should turn on. |
koozy |
Dec 5 2017, 02:37 PM
Fuel pump running now. No white wire coming from the ECU to the coil
JeffBowlsby |
Dec 5 2017, 03:16 PM
914 Wiring Harnesses Group: Members Posts: 8,484 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The single white wire is from the FI harness.
timothy_nd28 |
Dec 5 2017, 04:22 PM
Find and install this wire, most definitely needed! You should have 3 wires leading to the negative terminal and one wire to the positive side of the ignition coil.
Dec 5 2017, 06:16 PM
Definitely need the single white wire connected to the coil (-) terminal. That is what tells the FI when to open the injectors!
There is also a wire in the FI wiring harness that hooks up to the T-IV connector at the right-rear of the relay board. I believe that tells the FI when the starter is cranking. --DD |
koozy |
Dec 8 2017, 06:25 AM
Yep, it was the white wire. Found it, connected and fired up. Thanks, guys. I really appreciate it.
Mike |
Lo-Fi Version | Time is now: 28th April 2024 - 05:07 AM |
