914's and harness belts....., do i need a bar, do i need.... |
xsboost90 |
May 27 2005, 11:03 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
couldnt find any previous discussions on this that were answered. For those of you w/ harness belts, im buying a set of belts today, and I dont have a harness bar. I DO have some seats w/ the cool holes in the headrest though. I believe i can mount the shoulder straps to the firewall w/ big washers that come in the kit w/o the bar, is there a trick to i or can i not do this? The lap belts just go to the factory bolts correct? where does the submarine belt go? I need to run a bolt through the floorboard? (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) 5point harness.
skline |
May 27 2005, 11:07 AM
That is exactly as I did mine, the way you just described it. However, I will not be able to install the factory backpad in mine without some modifications. I need to figure that out pretty soon.
914helo |
May 27 2005, 11:11 AM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
I remember seeing someone's picture awhile back that showed them putting in a 6 point harness so that they wouldn't have to drill a hole through the floorboard like you would for a 5 point. Anything that saves putting more holes in and worrying about future rust seems like a good idea. Next year that's the route I plan on taking.
xitspd |
May 27 2005, 11:16 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
Make sure you use the same large washers(2.25"min.) for the submarine strap that you use for the shoulder straps. I use two large washers per eyebolt, one inside the drivers compartment and one outside the driver compartment....
Jeroen |
May 27 2005, 05:39 PM
better use some BIG ASS washers...
better yet, put in a backing plate of sheetmetal |
Aaron Cox |
May 27 2005, 05:44 PM
for the vertical belts:
2 eyebolts through the firewall. a 2.25" washer on each side and ive been told to double nut it also (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.ioportracing.com/images/thumbnail/r-washer.gif)(IMG:http://www.ioportracing.com/images/thumbnail/r-eyebolt.gif) for the laps , im told you can use these (IMG:http://www.ioportracing.com/images/product/r-bolt-in.gif) or use an eyebolt on each end to replace the stock bolt |
xitspd |
May 27 2005, 06:48 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Use a snap end with an Eye Bolt.....
Lo-Fi Version | Time is now: 7th May 2024 - 10:29 PM |
