xsboost90
May 27 2005, 11:03 AM
couldnt find any previous discussions on this that were answered. For those of you w/ harness belts, im buying a set of belts today, and I dont have a harness bar. I DO have some seats w/ the cool holes in the headrest though. I believe i can mount the shoulder straps to the firewall w/ big washers that come in the kit w/o the bar, is there a trick to i or can i not do this? The lap belts just go to the factory bolts correct? where does the submarine belt go? I need to run a bolt through the floorboard?
5point harness.
skline
May 27 2005, 11:07 AM
That is exactly as I did mine, the way you just described it. However, I will not be able to install the factory backpad in mine without some modifications. I need to figure that out pretty soon.
914helo
May 27 2005, 11:11 AM
I remember seeing someone's picture awhile back that showed them putting in a 6 point harness so that they wouldn't have to drill a hole through the floorboard like you would for a 5 point. Anything that saves putting more holes in and worrying about future rust seems like a good idea. Next year that's the route I plan on taking.
xitspd
May 27 2005, 11:16 AM
Make sure you use the same large washers(2.25"min.) for the submarine strap that you use for the shoulder straps. I use two large washers per eyebolt, one inside the drivers compartment and one outside the driver compartment....
Jeroen
May 27 2005, 05:39 PM
better use some BIG ASS washers...
better yet, put in a backing plate of sheetmetal
Aaron Cox
May 27 2005, 05:44 PM
for the vertical belts:
2 eyebolts through the firewall. a 2.25" washer on each side and ive been told to double nut it also
for the laps
, im told you can use these
or use an eyebolt on each end to replace the stock bolt
xitspd
May 27 2005, 06:48 PM
Use a snap end with an Eye Bolt.....
