WTB: Speed nut, screws & accelerator pedal clevis |
76-914 |
Dec 9 2017, 09:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I need the 6 speed nuts and 6 screws for the gage cluster. 2 of the 6 screws are a tad bit longer than the others. Also looking for the clevis pin used to attach the cable to the pedal assm. I checked McMaster-Carr, Bel-Metric and Zoro for the clevis but no dice.
bdstone914 |
Dec 10 2017, 08:03 AM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have clutch clevises and pins. Also have the SS spring loaded pins that I use in the pedal sets.
PET shows the screws to be 4,2 x 13 and 9.5mm Oval head self taping screw. I think the ones that go in the bottom are the shorter ones. I might have some of those. I sort some of the small hardware. Depending on how soon you need them you can order the correct screws from Belmetric.com Or use a common U.S. size. edit. I found thes new stainless screws ans clips. #8 US size. You may need the shorten two of the screws the go in the bottom edge of the bezel frame. If you dont like the SS screws you can paint the heads black. Bruce Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 07:20 AM |
