911 suspension compatibility question |
jt914 |
Dec 9 2017, 12:09 PM
I love my914 Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California |
jpnovak |
Dec 10 2017, 02:29 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
Those are 74-89 underbody sway bars. These will only work if you have the aluminum cross-member, rear tie-connectors and underbody specific sway bar bushing brackets that mount to the rear tie connectors.
You need the full system to run that sway bar. The a-arms by themselves will work. If you want to run a through-body sway bar, cut off the sway bar mounts and have the new drop link mount welded (better) or bolted in place. |
bdstone914 |
Dec 11 2017, 08:24 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[quote name='jpnovak' date='Dec 10 2017, 02:29 PM' post='2556568']
Those are 74-89 underbody sway bars. These will only work if you have the aluminum cross-member, rear tie-connectors and underbody specific sway bar bushing brackets that mount to the rear tie connectors. You need the full system to run that sway bar. Sorry, you are totally wrong on the sway bar. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:08 PM |
