Fuel Line help, Fuel Line help |
simonjb |
Dec 9 2017, 06:36 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I purchased a great SS fuel line set from Tangerine for my 2.3 Carb conversion. I am mounting the Carter fuel pump and filter on the firewall to the right of the end of the SS line that come through the firewall.
I just can't seem to figure out how this small SS line goes up through the engine shelf. Chris has emailed me trying to help me, but I am just not getting it. It seems the line is too long or reversed or something? Has anyone installed this? Attached thumbnail(s) |
iankarr |
Dec 9 2017, 08:32 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Strange. It looks in your pics as if the two holes where the lines are supposed to go have been covered over. Or maybe they’re hidden by the paper. They should be under the battery tray and a little bit towards the firewall. Here’s a link which has pictures that show where the fuel lines go up into the engine compartment. There should also be 45° angle rubber grommets to protect the lines from rubbing against bare metal.
http://www.914world.com/specs/tech_fuellines_ss.php The engine shelf hole you’ve got the supply SS line poking through in the second pic is for the fuel pump wiring and oil temp sender grommet. Here’s a vid I made of the install. Hope it helps! https://m.youtube.com/watch?v=IDFsZoI_W3g |
iankarr |
Dec 10 2017, 09:15 AM
simonjb |
Dec 10 2017, 09:19 AM
Thanks!
So I think I understand now. First, the clip is there - but its yellow, so you can barely see it. The main problem is we repaired a bit of rust in the Hell hole and replaced the shelf to make it all look clean - and thus forgot the fuel line hole! |
ndfrigi |
Dec 10 2017, 10:42 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
iankarr |
Dec 10 2017, 04:54 PM
Thanks! So I think I understand now. First, the clip is there - but its yellow, so you can barely see it. The main problem is we repaired a bit of rust in the Hell hole and replaced the shelf to make it all look clean - and thus forgot the fuel line hole! Glad you got it sorted out! I see the yellow clip. There's another one near the top of the lines, which I added a shot of in my previous post. PS Great pic, Ndfrfigi! |
simonjb |
Dec 11 2017, 06:33 PM
Now new hole and grommet - line installed
Lo-Fi Version | Time is now: 5th May 2024 - 01:52 PM |
