914 1975, Steering lock (tumbler) removal |
puzzled |
Dec 21 2017, 11:43 AM
Newbie Group: Members Posts: 9 Joined: 26-July 17 From: UK Member No.: 21,287 Region Association: England |
I am trying to re-key my 1975 ignition lock, how do you remove the tumbler? I have removed the alloy casting but cannot see how the lock can be removed!
gms |
Dec 21 2017, 01:45 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
The later ignition housing became more tamper-proof in 1975. here is a Link to remove it
phillstek |
Dec 21 2017, 01:46 PM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Remove the steering wheel, wiper and indicator switches. The switches push through the column housing from the rear after unplugging the harness connectors, Be careful as these parts can be brittle from age and the accumulated dirt can make them difficult to move at first but after some gentle jiggling they should slide forward readily.
Once these switches are removed you should see two screws holding the barrel in place, remove these and the barrel should slide out. Hopefully the steering lock is not locked as it needs to be unlocked for the barrel to slide forward. Good luck, |
rgalla9146 |
Dec 21 2017, 01:57 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I am trying to re-key my 1975 ignition lock, how do you remove the tumbler? I have removed the alloy casting but cannot see how the lock can be removed! You've got to drill a hole in the casting to access a leaf spring that has to be pushed in to release the tumbler. Can't describe the location. Been a long time since I've done it. Someone will probably chime in. Or....Google it. |
914Sixer |
Dec 21 2017, 04:29 PM
DO NOT attempt to rekey it yourself. Have it done. 75-76 locks have a set of cam rollers instead of the slot type. Lock will be a nightmare trying to get back together.
Chris914n6 |
Dec 21 2017, 05:32 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 17th May 2024 - 06:15 PM |
