Engine deck lid rubbing, on trunk |
jcambo7 |
Dec 21 2017, 09:47 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
jcambo7 |
Tom_T |
Dec 21 2017, 10:04 PM
Check the engine lid hinge on that side to see if the weld has pulled loose, or bent or deformed; if not there then check th spring bars etc. to see which is wanky.
(IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
ndfrigi |
Dec 22 2017, 12:34 AM
yes check the hinge under the lid right forward just below the rear window firewall. Hope the bolt is just loose and not the usual broken L bracket attached to
the firewall. |
Dec 22 2017, 01:23 AM
L-shaped bracket on the firewall has cracked, is on its way to being an | shaped bracket. BTDT.
--DD |
jcambo7 |
Dec 23 2017, 09:46 AM
I figured it out. Thanks for the help.
Lo-Fi Version | Time is now: 17th May 2024 - 07:59 PM |
