So my engine deck lid is rubbing on the trunk on the passengers side. It wasn't like this until recently. Anyone have any ideas what is causing it and how to fix it?
Check the engine lid hinge on that side to see if the weld has pulled loose, or bent or deformed; if not there then check th spring bars etc. to see which is wanky.
Tom ///////
ndfrigi
Dec 22 2017, 12:34 AM
yes check the hinge under the lid right forward just below the rear window firewall. Hope the bolt is just loose and not the usual broken L bracket attached to the firewall.
Dave_Darling
Dec 22 2017, 01:23 AM
L-shaped bracket on the firewall has cracked, is on its way to being an | shaped bracket. BTDT.
--DD
jcambo7
Dec 23 2017, 09:46 AM
I figured it out. Thanks for the help.
