Progress on the reassembly, Engine bay |
914_7T3 |
Aug 17 2018, 06:31 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
worn |
Aug 17 2018, 06:44 PM
can't remember Group: Members Posts: 3,148 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Holy smokes this is inspiration! Seems like you are getting close. (IMG:style_emoticons/default/beer3.gif) Last time I read about a poodle and diabolically cool work was in Faust. And the poodle’s master was very capable. Gotta go dog shopping... |
JmuRiz |
Aug 17 2018, 08:25 PM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Amazing detail!
Looking great |
simonjb |
Aug 17 2018, 09:30 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Holy smokes this is inspiration! Seems like you are getting close. (IMG:style_emoticons/default/beer3.gif) Last time I read about a poodle and diabolically cool work was in Faust. And the poodle’s master was very capable. Gotta go dog shopping... ha! Sometimes when the assembly isn’t going well I think of making a pact with the Devil. |
simonjb |
Aug 18 2018, 03:16 PM
So, my thoughts of a quick engine install was not to be - I got everything ready with the engine on a jack cart and the car up on a lift. Thought was to easily drop the car down on the engine. Then when I’m all ready, I finally realize that the engine bar and engine tin are too wide for the inside tracks of the lift (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
So two choices, take engine out from under the lift and then get car on the ground and do it the normal way or, remove the engine bar and one side of the engine tin and stick with original pla. Of course I chose the hard way and removed the bar and tin. Easy off, hard back on. In any case, it’s back together and engine is sitting in engine bay ready to finish up tomorrow. |
simonjb |
Aug 18 2018, 03:17 PM
simonjb |
Aug 18 2018, 03:19 PM
raynekat |
Aug 18 2018, 07:27 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Super clean looking engine....super job!
simonjb |
Aug 19 2018, 04:51 PM
simonjb |
Morph914 |
Aug 20 2018, 07:58 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Kudos to you for a fantastic build! I will be referring to it as I put mine back together. I will say that this is the perfect color to show off the detail of your great work. The contrast is great between the black and yellow, it would not have been the same on a darker color.
A couple of questions: are you running a return line to the the fuel tank? I didn't see one. Any issues with clearance on the oil cooler and engine? Will this be a fair weather car? I did not notice any undercoating. Forgive me if I have repeated any questions already asked, as I did not read all of the replies. Cheers, John |
simonjb |
Aug 20 2018, 05:08 PM
Kudos to you for a fantastic build! I will be referring to it as I put mine back together. I will say that this is the perfect color to show off the detail of your great work. The contrast is great between the black and yellow, it would not have been the same on a darker color. A couple of questions: are you running a return line to the the fuel tank? I didn't see one. Any issues with clearance on the oil cooler and engine? Will this be a fair weather car? I did not notice any undercoating. Forgive me if I have repeated any questions already asked, as I did not read all of the replies. Cheers, John Hi John, It will be a fair weather car...hence I decided not to do any undercoating. Even though I measured 6 times, I managed to put the oil cooler such that a small part hits the edge of a nut on the transmission. So I'll have to move it slightly. Grrrr. No return line. I'll put one in if I re-install the original engine. Thanks for the comments... |
simonjb |
Aug 22 2018, 02:32 PM
simonjb |
Aug 22 2018, 02:34 PM
simonjb |
Aug 22 2018, 02:36 PM
simonjb |
Aug 22 2018, 02:38 PM
defianty |
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
All looking fantastic, such a great build.
If it were me I'd be looking to get those oil lines off of the heat exchangers, they do get hot. |
simonjb |
Aug 22 2018, 02:39 PM
simonjb |
Aug 22 2018, 02:41 PM
bbrock |
Aug 22 2018, 03:38 PM
Connected all the starter motor wires Finally caught you skimping on something! (IMG:style_emoticons/default/laugh.gif) There is a rubber protector cap for the starter cable that is still available pretty cheap. Part # is 999-659-006-50. It will make your car run faster. (IMG:style_emoticons/default/rolleyes.gif) Looking great! Getting close to the big moment! |
Lo-Fi Version | Time is now: 26th April 2024 - 11:17 PM |
