for those running 944 hubs/ 911spindles, ever have clearance problems? |
xsboost90 |
May 30 2005, 09:49 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
so i have a 78 911 spindle setup, w/ some early 944 hubs and 911 rotors-which are the same as the 911 rotors actually. Now i had to space the calipers to fit the rotor since the hubs sit closer to the a-arms now than the stock ones. I noticed while lowering the car that the ball joint started to hit the rotor or get extremely close when it got too low. I took and "contoured" the outer point of the arm down for added clearance, but i also raised the car back up alot. Im thinking im gonna need some 911 hubs after all..anyone using 944 hubs with this problem. anyone have any 911 hubs?? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 11:54 PM |
