Hand Written Number under the Dash |
Mike Fitton |
Jan 1 2018, 09:49 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Changed out my dash today to the correct early version on my 914-6. Saw the hand written black marker number under the dash and it does not match my rear trunk number. Under dash number is 130xxx rear trunk is 132xxx does this seem right?
ConeDodger |
Jan 1 2018, 09:53 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Changed out my dash today to the correct early version on my 914-6. Saw the hand written black marker number under the dash and it does not match my rear trunk number. Under dash number is 130xxx rear trunk is 132xxx does this seem right? Mine had a color written and the dash frame was that color. |
porschetub |
Jan 1 2018, 10:06 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Appears the 911's have the same marking,is it done with a yellow wax pensil?
Unobtanium-inc |
Jan 1 2018, 10:07 PM
Advanced Member Group: Members Posts: 2,210 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Appears the 911's have the same marking,is it done with a yellow wax pensil? Looks like this, this was a 67S. Attached thumbnail(s) Attached image(s) |
Mike Fitton |
Jan 1 2018, 10:14 PM
No mine was a black marker and on the bottom side of the dash, I will take some pictures tomorrow and post them here.
Jan 1 2018, 10:37 PM
All 4 of my dashes that I have in storage have a similar number in marker.
sithot |
Jan 2 2018, 07:49 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Under the dash pad on the 911 Porsche (eventually) changed these numbers to a "production number" and they never matched the chassis.
The only way to find out whether these "numbers match" is to contact the factory. If they do match they'll say so but if they don't you will not get the correct number from them. The upside of this is that re-bodied cars can be rooted out. Here is a thread from the Early S Registry regarding this: http://www.early911sregistry.org/forums/sh...umber-Locations |
Cairo94507 |
Jan 2 2018, 08:19 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Mike - My understanding is the number handwritten under the dash, should be the chassis number stamped into the center back panel of the car trunk. Does it appear the rear trunk panel was ever replaced?
gms |
Jan 2 2018, 10:38 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Changed out my dash today to the correct early version on my 914-6. Saw the hand written black marker number under the dash and it does not match my rear trunk number. Under dash number is 130xxx rear trunk is 132xxx does this seem right? Mike, The number in your trunk is the Karmann serial number; generally the Karmann number is also written under the dash. It is not uncommon for the dash and trunk to not match. The example below is for Karmann # 131846 I believe they added a "0" for 1970 under the dash. |
Mike Fitton |
Jan 2 2018, 11:27 AM
Changed out my dash today to the correct early version on my 914-6. Saw the hand written black marker number under the dash and it does not match my rear trunk number. Under dash number is 130xxx rear trunk is 132xxx does this seem right? Mike, The number in your trunk is the Karmann serial number; generally the Karmann number is also written under the dash. It is not uncommon for the dash and trunk to not match. The example below is for Karmann # 131846 I believe they added a "0" for 1970 under the dash. Thanks Glenn, yep same black marker used on mine. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:32 PM |
