Trunk prop rod |
Trunk prop rod |
Front yard mechanic |
Jan 4 2018, 05:53 AM
Senior Member Group: Members Posts: 1,169 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
This is an easy project and you can get pretty creative with it. Here's mine for my fiberglass hood. It was made with stuff I already had in the garage. (IMG:style_emoticons/default/biggrin.gif) Wondering why you carry dinamite as standard equipment (IMG:style_emoticons/default/blink.gif) |
mgp4591 |
914 Guru Group: Members Posts: 5,380 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Go to your local Pick n Pull, find a couple of Hondas or Toyotas and pull the hood prop rods and associated hardware out. Use some creativity, fit and install. Lightweight with no wear issues and pretty cheap.
Jan 4 2018, 07:43 AM
914-6 GT in waiting Group: Members Posts: 19,306 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
this is what I'd like to do: simple yet elegant You take the prop rod, I'll take the gas tank. (IMG:style_emoticons/default/biggrin.gif) |
90quattrocoupe |
Jan 4 2018, 10:26 AM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Adjustable spring loaded window curtain rod with rubber cups at both ends.
Greg W. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:15 AM |
