Gauging interest Hyd M/C brackets |
dwillouby |
Jan 3 2018, 05:40 PM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello,
I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. David |
bdstone914 |
Jan 4 2018, 08:09 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
[quote name='dwillouby' date='Jan 3 2018, 05:40 PM' post='2564027']
Hello, I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. If you laser cut that bracket it about be about $10. Offering a whole kit made sense. What clutch master does that fit ? What pedal set is used ? Many missing pieces to the puzzle. |
dwillouby |
Jan 4 2018, 08:56 AM
[quote name='bdstone914' date='Jan 4 2018, 07:09 AM' post='2564185']
[quote name='dwillouby' date='Jan 3 2018, 05:40 PM' post='2564027'] Hello, I am looking at producing some additional Hyd clutch master cyl mounting brackets again. I will have to farm out to a shop to make as I no longer have access to a mill. Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s. If you laser cut that bracket it about be about $10. Offering a whole kit made sense. What clutch master does that fit ? What pedal set is used ? Many missing pieces to the puzzle. [/quote] If laser cut is acceptable (finish not as nice as machined) cost will come down. I used a pedal set from a 76 for the prototype. This uses the standard Wilwood master cyl. I can supply a list of part numbers / vendors. I cant get a better price on the parts than anyone else. Made and sold several of these in the past with no complaints. David |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:52 PM |
