GB from 914Rubber water hoses like factory ! (3 of 200), Full set $20 all you need to replace the system |
Mikey914 |
Jan 13 2018, 04:15 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So thanks to a customer doing a high end restoration we made the rubber hoses like factory used. Others are offering a clear hose that is well... just not period correct.
The hose kit consists of the tire to male end connector (hose shown). The short hose to the cap The tank hose to stalk Stalk to T fitting hose 2 (one long one short) t fitting to squirter hoses I have them bagged in sections to help make it easier. One thing we did diferently was make the hose slightly thicker to give it more grip on the fittings. So you will not need to band them like factory did to get them to stay. They are a VERY tight fit and will require some soappy water to install on the fittings. These are not cheap silicone hoses, and have the correct gloss level. We did a limited run on these and onl have enough material for 30 sets on hand. Who's in? Attached thumbnail(s) |
branston |
Jan 23 2018, 08:55 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
I was super excited to receive mine tonight, I'm not sure which route USPS uses to get parts from OR to MI in nine days. USPS first class mail gets slower for sure NOT 914rubber's fault let me be clear.
Excited to open the padded mailer I received, I was confronted with a bag of black pre-cut hose, so where was the assembly I saw on the listing?? complete with cap and valve connections? here I own up to being dumb and hurried, ordered excitedly as it looked like it included the whole assembly. Embarrassingly I'm the guy that sells washer hose on Samba to VW owners to fix their tired washers and I have 100ft rolls of the same hose......... Would anyone like mine. just let me know......... 914rubber can you indicate on your website that it is JUST for the rubber hose? Please. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:16 AM |
