Correct connecting rod for 914-6? |
Bob Wolcott |
May 30 2005, 08:31 PM
Member Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
http://oregonstate.edu/~wolcottr/Porsche/DSCF0001.JPG
This appears to be the right connecting rod for my engine (stock -6) but I wasn't sure what the final digit (the S) was for. Anyone know what it means? Thanks, Bob |
TimT |
May 30 2005, 08:40 PM
I see 901.103.101.0R then the manufacturers stamp
anyhoo, the rod is in the engine your taking apart isnt it? one would hope it was ok to begin with |
ArtechnikA |
May 30 2005, 09:05 PM
looks like a KolbenSchmidt hallmark to me ... |
Bob Wolcott |
May 30 2005, 09:20 PM
I don't doubt that it is fine and will work but the engine has been rebuilt before (and increased to 2.2L) so I am just curious what parts might have been replaced or upgraded. So far everything appears to be what it should be, but I'm not exactly an expert.
Thanks for the help, Bob |
brp914 |
May 30 2005, 09:46 PM
Unregistered |
at a minimum you got 84 mm p/c. check also for piston oil squirters, oil bypass modification, 930 or carrera tensioners, replaced "wire" crank w/ counterweighted. heads should be reblt only once. If you need another set, I have 2 fresh sets laying around here, lemme know. I'm in la.
Lo-Fi Version | Time is now: 19th May 2024 - 08:33 PM |
