wheel sizes... will 16x8 work with flares? |
holtby914 |
Jan 14 2018, 02:42 PM
Newbie Group: Members Posts: 42 Joined: 16-November 16 From: Ontario, Canada Member No.: 20,593 Region Association: Canada |
Trying to figure out what is the biggest wheels that will fit with gt flares... anyone have some advice? I found some decently priced generic steal wheels from diamond wheels that are 16X8(-12 offset). Can they be made to fit?
Mueller |
Jan 14 2018, 06:27 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311
^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. |
holtby914 |
Jan 14 2018, 08:09 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? |
Mueller |
Jan 14 2018, 08:30 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? Better brakes with 5 lug if you swap over to 911 front suspension. /4 front are solid rotor 911 front is vented and there are kits to put larger and lighter calipers. Besides being cheap why the Circle track heavy steel rims? Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money. |
holtby914 |
Jan 14 2018, 08:41 PM
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311 ^ His offset should be (no mention of spacers used) F = 23.3mm R = 15mm] I like http://www.willtheyfit.com/ for playing with offsets. Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from? Better brakes with 5 lug if you swap over to 911 front suspension. /4 front are solid rotor 911 front is vented and there are kits to put larger and lighter calipers. Besides being cheap why the Circle track heavy steel rims? Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money. I can always upgrade the wheels while doing the brakes and hubs, in the future. I have brand new refurbished brakes that I put on the car, they will work for now. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:42 PM |
