Crossmember difference 4/6 914, Yes, they are different |
Cairo94507 |
Jan 15 2018, 08:21 AM
Michael Group: Members Posts: 9,714 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Recently brought to my attention when I collected my parts from the shop back east, I mistakenly got a 4 cylinder crossmember back, not my correct 6 cylinder crossmember. That led me to learn, (thanks Jim, aka Banananose) how to differentiate the two. Here you go:
This is a 4 cylinder crossmember: This is a correct 6 cylinder crossmember: I hope that helps in the future. (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Jan 16 2018, 08:19 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
one learns something every day, never noticed the difference. Thanks for sharing. Just went out and looked at a six and a four. Sure enough
mskala |
Jan 16 2018, 09:33 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I disagree.
6-cyl photo (sorry for quality but I have another car under it right now). |
mepstein |
Jan 17 2018, 06:16 AM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
mskala |
Jan 17 2018, 07:57 AM
Do they have a part number stamped on the crossmember?
Another thing, I'll get a better pic, but the adjuster screws just have an 8mm hex section welded onto the threaded section. |
mepstein |
Jan 17 2018, 08:18 AM
gms |
Jan 17 2018, 11:04 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Should have 911 type support (with flat side) and early allen head adjuster
gms |
Jan 17 2018, 12:20 PM
mskala |
Jan 17 2018, 07:10 PM
All I know is I bought this car in '99 from a guy who had it since '74, and lots of
records and kept old parts. Highly doubtful that it was changed. |
mepstein |
Jan 17 2018, 08:17 PM
914Sixer |
Jan 17 2018, 10:46 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have seen them all the ways shown. I maintain it was what they had on the shelf that week. The square end cross member looks to be 901 341 013.02. According to the PET 69-73 911 and all 914 share the same cross member 901 341 013 03. Version 01 was for the 64-68 cars.
Jonathan Livesay |
Jan 19 2018, 04:32 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
I disagree. 6-cyl photo (sorry for quality but I have another car under it right now). Mine has the same as yours. My car is vin #9140430275, I see from the vin# list that your vin is 33 down from mine, I wonder if that has anything to do with which type was used? Of course over over 48 years who knows what might have been changed and why. |
gms |
Jan 19 2018, 06:33 PM
I would be interested to know if you have 914/4 a-arms as well?
Do you both have 914/6 Boge strut towers? |
mepstein |
Jan 19 2018, 06:45 PM
gms |
Jan 19 2018, 06:48 PM
I have seen them all the ways shown. I maintain it was what they had on the shelf that week. The square end cross member looks to be 901 341 013.02. According to the PET 69-73 911 and all 914 share the same cross member 901 341 013 03. Version 01 was for the 64-68 cars. My parts catalog shows: 914-4 = 914 341 013 03 914-6 = 901 341 013 03 911 with shock absorber struts is 901 341 013 03 (1970-71) 911 with shock absorber struts is 911 341 013 05 (1972-73) 911 with spring struts is 901 341 013 03 as I recall the pre 1969 911 suspension was a totally different animal |
mskala |
Jan 19 2018, 10:04 PM
I have Boge struts and 911-splined arms.
Jonathan Livesay |
Jan 20 2018, 11:11 AM
mepstein |
Jan 20 2018, 11:15 AM
I have Boge struts and 911-splined arms. I know the torsion bars are different splines than on my 4 cylinder cars. If it has 6 front brakes then it has 6 struts, no? My car is completely disassembled, I will check next time I am over at my garage. If it has 6 front brakes then it has 6 struts - correct. Original color would be grey. |
gms |
Jan 22 2018, 02:43 PM
I have Boge struts and 911-splined arms. I know the torsion bars are different splines than on my 4 cylinder cars. If it has 6 front brakes then it has 6 struts, no? My car is completely disassembled, I will check next time I am over at my garage. -6 struts 914.431.092.00 914.431.093.00 |
dug |
Feb 11 2018, 08:19 PM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
The 914-6 cross member with flat ends, and the front and rear torsion bar carriers all have a P in the Triangle stamp indicating a Porsche part.
The 914-4 cross member and torsion bar carriers all have VW stamps. A part's presence in a 48 year old car does not prove anything. Porsche would not have had the 914-4 parts on their shelf. A lot can happen in the first 3 years of ownership. It would not surprise me if someone hit a curb hard and bend the control arm and screwed up the crossmember. The VW part is totally compatible, so sourcing one from a junk yard would have been the obvious move in 1970-1973. cheers, dug |
Lo-Fi Version | Time is now: 27th April 2024 - 04:14 AM |
