Complete 911 Carrera Ft Suspension - Side to Side - Everything !, 2-4-18 8PM Pending Pickup |
toolguy |
Jan 19 2018, 03:48 PM
Senior Member Group: Members Posts: 1,269 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
This is a complete 911 SC/Carrera front suspension. . Has 3 1/2 inch A type calipers. Complete, nuts, bolts, the whole works. Everything new or fresh restored as pictured except the used Koni's. Just removed from an undriven restored car. Clean, restored with fresh powder paint and plating. It has new Lemforder Ball Joints. All new wheel bearings and seals with new Porsche brake pad kits. Includes wheel bearing nuts and washer and dust covers. Rotors were turned. Both calipers rebuilt using real ATE kits, with new hard and ATE soft brake lines included.
Has OE Porsche factory rubber A arm bushings installed in mounts already pressed on. Struts have new wedge bolts, and strut cartridge nuts. Aluminum cross member with 20 mm sway bar, mounts and bushings. Has 19 mm Porsche torsion bars with caps and adjusters. Only thing you need to provide is the 4 front A arm bolts and the 2 cross-member mount bolts. . they are the same as on a 914-4. And brake fluid. . local pickup San Diego If you want this shipped, I'll crate it for $100 on a pallet in a custom wooden box and you arrange and pay for shipping. 2-4-18 8PM Pending Pickup Attached image(s) |
Larmo63 |
Feb 6 2018, 09:44 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
That was a smoking deal. You could NOT put this together for that money.
Well bought!!!! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th May 2024 - 08:53 AM |
