Are there any 914 conversion using straight /6, Dont ever recall seeing one |
thelogo |
Jan 26 2018, 11:14 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Just curious as the straight 6 seem to be pretty
Powerfull But is this just the least desirable fit as far as 914 engine bay This for your consideration also https://losangeles.craigslist.org/sfv/cto/d...6470783992.html Whats this car all about ? And photo attached 1997 diesal dodge 6 , 215 hp , 485 ft/lbs torque Not bad Attached image(s) |
mgp4591 |
Jan 26 2018, 11:21 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Yep, too long.... you'll see Vs and flats but no inlines. Why, do you have a spare RB25 sitting around?? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
brant |
Jan 26 2018, 11:32 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Seriously. Have you ever looked at the diesels. My dodge motor in my tow vehicle is supposed to weigh 1400lbs dressed.
My 914 race car has a 6 cylinder motor and less hp... but handles due to its weight... 1826lbs wet |
burton73 |
Jan 26 2018, 11:49 PM
burton73 Group: Members Posts: 3,525 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Hell the car has chrome bumpers front and rear. That is worth $800
It says 300 miles on Eng. and trans. You are not that far go take a look. Maybe drive it home. The intake manifold looks old not 300 miles Its got some good stuff and you may be able to clean it up and have a nice V8 for low dollars if it is not all rusty. Bob B 1973 Porsche 914 5.7 Liter Small Block Chevy 350 Conversion About 300 miles on engine and transmission Renegade Hybrids SBC Conversion Kit 9" Clutch Upgrade (KEP - Kennedy Engineering in Palmdale, CA) sold by Renegade Hybrids Renegade Hybrids plug and play wiring harness 4 bolt main 350 crate motor, edelbrock 750cfm carb, 50K Summit Racing HEI, Hooker Header ceramic coated shorty headers, low profile ram style air intake to cone filter, summit turbo mufflers Narrow band digital stoichometer guage (carb lean/rich indicator), phantom autometer oil pressure & water temp Rebuilt 901 4-Speed (gears F - N - X - flipped H) 1st gear locked Swepco synthetic trans fluid drilled and wired CV bolts by RJMII JWest style custom shift linkage Modded factory tach for V8 engine & Hi torque starter Hard fuel lines from tank to engine bay Stainless Steel Braided DOT brake lines 19mm brake master cylinder 911 Turbo Tie Rods & steering rack boots, bump steer kit, tie rod spacing washer. New front and rear bushing kits installed, plus camber shims installed in rear Tangerine Racing Racing Delrin 914 Steering Coupler Rebuilt front and rear brakes Rear bilstein yellow hd shocks LED 3rd brake light JWest fuse panel (to use standard fuses) Momo competition steering wheel (with Porsche horn button) 2 row aluminum radiator with dual electric fans and custom shroud Billet front Grille (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) |
wes |
Jan 27 2018, 12:19 AM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I’d clean the engine, interior and go for rat rood surprise!
thelogo |
Jan 27 2018, 01:15 PM
It did seem like a hell of a deal but
Since im not mechanical inclined wanted to See what you v8 guys thought |
gandalf_025 |
Jan 27 2018, 02:06 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Seriously. Have you ever looked at the diesels. My dodge motor in my tow vehicle is supposed to weigh 1400lbs dressed. My 914 race car has a 6 cylinder motor and less hp... but handles due to its weight... 1826lbs wet Those diesels weigh enough to trash the suspensions on 3/4 Ton Heavy Duty Rams... And they eat transmissions.. I’ve had 2 and the only part of the Truck that didn’t self destruct Was the engines, because a Dodge didn’t build them. On the 2 valve engines, redline is around 2800 rpm. The later 4 valve ones did 3200 I think.. |
Jan 27 2018, 09:58 PM
Yep, too long.... you'll see Vs and flats but no inlines. (IMG:style_emoticons/default/agree.gif) Measure the engine; measure the engine bay. Unless you want to remove the firewall, it's not really gonna fit. --DD |
Mueller |
Jan 27 2018, 10:23 PM
Straight six engines belong in trucks and boats (or old Jags and Datsuns)
Unobtanium-inc |
Jan 27 2018, 10:56 PM
Advanced Member Group: Members Posts: 2,210 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Here's an interesting one, custom valve covers.
Jan 28 2018, 12:22 PM
That looks a lot like a V8, not an I6...
--DD |
Andyrew |
Jan 28 2018, 10:19 PM
My Audi inline 4 would physically fit, but running the audi transmission moved the CV joints to far forward, therefore I had to move back the firewall 6 inches (really only a couple, but I like room)
An audi Inline 5 would fit no problem in my current engine bay, but not a stock engine bay. but a 6 would just be too darn long. I know Mueller measured a VR6 and said it would work. Its supposed to be as long as the inline 4. |
nimblemotorsports |
Jan 28 2018, 10:40 PM
Newbie Group: Members Posts: 45 Joined: 12-January 18 From: Sacramento, California Member No.: 21,793 Region Association: None |
I'm sure it could be made to fit, you could use the valve covers for arm rests. (IMG:style_emoticons/default/happy11.gif)
thelogo |
Jan 29 2018, 02:06 PM
And what if you used
Traverse engine layout ala nsx Vs longitude layout |
Mueller |
Jan 29 2018, 02:42 PM
And what if you used Traverse engine layout ala nsx Vs longitude layout You might as well buy a Fiero, MR2, Fiat X/9 or said NSX that are made that way since there will be major reconstruction to adapt the transmission and cutting of the trunk firewall. It's been done before, one guy even used a Ford Escort drivetrain. No real reason to go thru that much trouble except for bragging(?) rights to say you did it. |
Chris914n6 |
Jan 29 2018, 02:54 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
My Nissan v6 with the Nissan FWD trans won't fit between the inner susp mounts. Neither would the targa top because the front of the trunk would need to be cut out.
Chris914n6 |
Jan 29 2018, 02:56 PM
Straight six engines belong in trucks and boats (or old Jags and Datsuns) and BMWs with twin turbos [335i] (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/biggrin.gif) |
worn |
Jan 29 2018, 02:58 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I dunno, but the smoothest car I drive is the TR6, with an inline 6. Feels like luxury after the 914/4. The H6 from Porsche is pretty smooth though too. Of course my modern Ford has no audible sign of an engine at all - watch it with the dog, ma'am.
Lo-Fi Version | Time is now: 19th May 2024 - 05:14 AM |
