Hell the car has chrome bumpers front and rear. That is worth $800
It says 300 miles on Eng. and trans. You are not that far go take a look. Maybe drive it home.
The intake manifold looks old not 300 miles
Its got some good stuff and you may be able to clean it up and have a nice V8 for low dollars if it is not all rusty.
Bob B
1973 Porsche 914 5.7 Liter Small Block Chevy 350 Conversion
About 300 miles on engine and transmission
Renegade Hybrids SBC Conversion Kit
9" Clutch Upgrade (KEP - Kennedy Engineering in Palmdale, CA) sold by Renegade Hybrids
Renegade Hybrids plug and play wiring harness
4 bolt main 350 crate motor, edelbrock 750cfm carb, 50K Summit Racing HEI, Hooker Header ceramic coated shorty headers, low profile ram style air intake to cone filter, summit turbo mufflers
Narrow band digital stoichometer guage (carb lean/rich indicator), phantom autometer oil pressure & water temp
Rebuilt 901 4-Speed (gears F - N - X - flipped H) 1st gear locked
Swepco synthetic trans fluid
drilled and wired CV bolts by RJMII
JWest style custom shift linkage
Modded factory tach for V8 engine &
Hi torque starter
Hard fuel lines from tank to engine bay
Stainless Steel Braided DOT brake lines
19mm brake master cylinder
911 Turbo Tie Rods & steering rack boots, bump steer kit, tie rod spacing washer.
New front and rear bushing kits installed, plus camber shims installed in rear
Tangerine Racing Racing Delrin 914 Steering Coupler
Rebuilt front and rear brakes
Rear bilstein yellow hd shocks
LED 3rd brake light
JWest fuse panel (to use standard fuses)
Momo competition steering wheel (with Porsche horn button)
2 row aluminum radiator with dual electric fans and custom shroud
Billet front Grille
