Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
Craigers17 |
Feb 24 2018, 11:36 AM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Looks great.....I know you said it's a 2.3, but can you give any build details, and/or who built it?
Mblizzard |
Feb 24 2018, 11:45 AM
Looks great.....I know you said it's a 2.3, but can you give any build details, and/or who built it? I have some of the history of the engine but not the exact builds details. Jansen Enterprise in Belmont CA Did the build. But has mostly the standard mods swivel foot rockers, 78mm crank, cam, dual spring big valve heads, lightened flywheel, and balanced. |
Mike Bellis |
Feb 24 2018, 11:54 PM
I have some of the history of the engine but not the exact builds details. Jansen Enterprise in Belmont CA Did the build. But has mostly the standard mods swivel foot rockers, 78mm crank, cam, dual spring big valve heads, lightened flywheel, and balanced. I know that guy. He does decent work. That engine should be put together correctly. He works on my buddy's drag Ghia T1. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:01 PM |
