Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
DRPHIL914 |
Feb 24 2018, 05:20 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so by the looks of this you gave up on the 2056 with fi??
Mblizzard |
Feb 24 2018, 06:26 PM
DRPHIL914 |
Feb 25 2018, 07:30 AM
so by the looks of this you gave up on the 2056 with fi?? Nope!its stil there ready to run. This one is FI as well and should put up some respectable HP numbers. Keeping the 2056 as a back up. Might be able to keep up with you soon! well, maybe (IMG:style_emoticons/default/poke.gif) , but its about handling and driving skill more than HP! (IMG:style_emoticons/default/shades.gif) but seriously i am sure you will kick some but and find some ditches with that set up. you should come down to robeling road for a pca de day when you gwt it ready! i am doing the same clean up and refresh of tin and other stuff while my motor is out - i am not gettimg into soing anything with my heads or p&c's right now, just clean up and leaks- i looked closer at your pictures and see the f.i. bits - are you going with a Tangetine header and wxhaust on the new motor too? shod be awesome! there was a Raby built 2.3 with all of Foley's stuff on it last weekend here at our cars and coffee- sounded awesome! he shold be coming to the Okteenerfest in Sept! |
Lo-Fi Version | Time is now: 17th May 2024 - 01:02 AM |
