Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
Mblizzard |
Mar 19 2018, 10:51 AM
Started the removal process of the 2056 to go to Germany!
Not too nasty but could use a bit of cleaning! Also ripped off the disgusting foil water holding cheap back pad material. Looks like I have some glue removal to do. Will start the rear wheel bearing and bushing replacement after I get the engine out. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:08 PM |
