Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
koozy |
Apr 1 2018, 08:23 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Are the bushings Delrin, hard plastic type stuff, or rubber and did you lube the shaft? Does the shaft spin smoothly, with little resistance, in the bushings before assembly?
Mblizzard |
Apr 2 2018, 04:54 AM
Are the bushings Delrin, hard plastic type stuff, or rubber and did you lube the shaft? Does the shaft spin smoothly, with little resistance, in the bushings before assembly? I assume you are talking about the shaft bushings. Not sure of the material but not soft rubber. Slightly hard plastic. Yes lube on shaft and it turns very smoothly. Once the nuts are tightened up there is more resistance. But super easy install compared to the trauma of putting the rubber ones in. |
Lo-Fi Version | Time is now: 16th May 2024 - 10:28 PM |
