Gauge restore and LED upgrade, step by step video |
iankarr |
Jan 31 2018, 10:15 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Just finished restoring my gauge cluster and installing the LED upgrade described by Timothy_nd28. Here's the vid... https://www.youtube.com/watch?v=r3xJxEiIlIQ And here's Tim's step by step post... http://www.914world.com/bbs2/index.php?sho...=212130&hl= |
Chris914n6 |
Jan 31 2018, 08:05 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Happen to measure the thickness of the glass?
I've got a guy that will cut glass cheap but my later gauge, with the plastic lens, is about half as thick. Same thing with my 944 combo gauge, only 1/16" or so thick. |
iankarr |
Jan 31 2018, 08:36 PM
Happen to measure the thickness of the glass? I've got a guy that will cut glass cheap but my later gauge, with the plastic lens, is about half as thick. Same thing with my 944 combo gauge, only 1/16" or so thick. Here ya go... this is original glass. 2.92mm / .115 inches (or 7/64). I replaced the ones on my gauges and just told the glazier to match the thickness. keep in mind that if you powder coat the rings you may need a slightly thinner glass. These lenses are installed under surprisingly tight tolerances and if the glass/ring combo is too thick, there won’t be enough metal left to re-crimp. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:14 AM |
