idle too low when warm ..., webers, 44 IDFs ... |
May 31 2005, 11:26 PM
my idle is too low when warm, cold idle is perfect ...
now i'm not a carb guy ... should i just turn up the idle so it's a bit high cold but ok warm? is that how it works? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
redshift |
May 31 2005, 11:29 PM
Yes... that would work, or you could adjust it when it's cold, then again when it's hot... everytime.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
May 31 2005, 11:32 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) you think there would be a market for a cockpit adjustable idle for dual carbs ??? (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
Dr. Roger |
May 31 2005, 11:38 PM
I used to run a well worn Holley in a pumped up Chevelle that did that also.
My auto shop teacher looked at it and deduced the butterfly valve was gummed up a little and worn. It was an old beater carb but after taking the thing apart and cleaning/fine tuning the throttle plates, it actually cleared up. dont know if that helps but there's my 2 cents.... =-) |
Joe Ricard |
Jun 1 2005, 04:56 AM
Well it could be thatyou have a vacuum leak cold and once the motor heats the leak is sealed. Ah never mnd I think I just pulled that out my ass. I just really don't know unless I got to tweak on it. Obviously something is askew if you run through the entire carb synch thing I wrote yesterday that might fix it.
ArtechnikA |
Jun 1 2005, 05:01 AM
Porsche thought so when they added the hand throttle lever to the /6's ... that's what it's for - adjust idle warm, keep it running with the hand throttle. if yours is idling perfectly cold and too slow hot, you might want to kick back a size on the idle jets or turn in the idle mixture screws "some" ... |
rhodyguy |
Jun 1 2005, 07:49 AM
if your car idles a bit high when cold and settles down to 900-950 when warm, i'd say you're good to go andy. no sneezing thru the carbs?, no back firing?, tanish plugs?, drive on man.
k |
nebreitling |
Jun 1 2005, 07:53 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
if it raises more than 200 or 250 rpms cold to hot, you might have a problem. other wise, adjust it a bit and drive on. i've got a sync tool if you need it. |
rhodyguy |
Jun 1 2005, 08:08 AM
i'd like to know the trick to getting the car to idle a bit high when cold and settle down when warm. just like f.i. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) . i have to feather the pedal on cold start up. mine works the opposite, low cold idle climbing to 950 or so when warm.
k |
nebreitling |
Jun 1 2005, 09:55 AM
you're right. dyslexic flare-up!!! edited my post.
rhodyguy |
Jun 1 2005, 10:30 AM
it was early in the am. check this out. note the chevy electric door lock acutator(?). (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) .
k Attached image(s) |
Aaron Cox |
Jun 1 2005, 10:36 AM
Lo-Fi Version | Time is now: 15th May 2024 - 08:05 AM |
