Corrosion Removal, LOL ~ |
914werke |
Feb 2 2018, 07:53 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Everyone on this board should be intimately familiar. (IMG:style_emoticons/default/biggrin.gif)
I thought we could try to aggregate solutions. Sawsall Torch Blasting Chemicals Vibratory You get the idea (IMG:style_emoticons/default/smile.gif) 1st question: Apple Cider Vinegar ? Cheap readily available, effective? What % (strength) is necessary? Pitfalls? (IMG:style_emoticons/default/rolleyes.gif) |
Feb 2 2018, 08:08 PM
ACV - works well for me. Cheap and non toxic. Doesn’t bother my wife if a bucket sits in the garage. You can use full strength or dilute with water. I just drop the parts in a bucket and let sit for a couple days or longer if needed. Wash with water and then paint, powder coat, ect. The bare metal will rust very quickly so spray with wd-40 if you are going to let sit. It worked great for cleaning out my motorcycle tanks and getting parts ready for plating.
914werke |
Feb 2 2018, 08:10 PM
Does it do anything to Alum?
beech4rd |
Feb 2 2018, 08:17 PM
Member Group: Members Posts: 343 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States |
Mikey914 |
Feb 2 2018, 11:39 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Acid is used as a pretreatment for plating. It opens up pours and cleans well. Just don’t leave in too long.
wndsrfr |
Feb 3 2018, 07:47 AM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Everyone on this board should be intimately familiar. (IMG:style_emoticons/default/biggrin.gif) I thought we could try to aggregate solutions. Sawsall Torch Blasting Chemicals Vibratory You get the idea.... (IMG:style_emoticons/default/rolleyes.gif) How about rollback?! (IMG:style_emoticons/default/lol-2.gif) |
worn |
Feb 3 2018, 10:53 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Everyone on this board should be intimately familiar. (IMG:style_emoticons/default/biggrin.gif) I thought we could try to aggregate solutions. Sawsall Torch Blasting Chemicals Vibratory You get the idea (IMG:style_emoticons/default/smile.gif) 1st question: Apple Cider Vinegar ? Cheap readily available, effective? What % (strength) is necessary? Pitfalls? (IMG:style_emoticons/default/rolleyes.gif) That uses the same mechanism as phosphoric acid. The phosphoric acid leaves a bit of iron phosphate on the metal, so there is a slight delay in rusting after treatment. |
Elliot Cannon |
Feb 3 2018, 11:30 AM
Apple cider vinegar is also good to treat muscle cramps. A teaspoon in a glass of water. (IMG:style_emoticons/default/beer3.gif)
bretth |
Feb 3 2018, 12:14 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
ACV kills warts too. Put a little under a bandaid and it turns black within day.
burton73 |
Feb 3 2018, 12:35 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Eric at PMB Performance told me he uses Ketchup to clean fuse blocks. It has vinegar in it. I took the block and put it in white vinegar and soaked it a little and then brushed it with a medium brush washed it off and blow-dried with an air gun.
Used a contact spray for relays. I use a tiger grit wheel for some stuff with 220 grit in the bristles for bolts and such. Bob B |
Feb 3 2018, 01:28 PM
Yep. White vinager. A couple hours and then scrub clean with an old tooth brush, soap and water
Lo-Fi Version | Time is now: 17th May 2024 - 02:58 AM |
