Return fuel line with carbs?, Anyone running return fuel line with cabs? |
lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
lonewolfe |
Feb 5 2018, 12:41 AM
I have Dellorto carbs so one has the menu intake line & a double banjo that then feeds the second carb. I was thing if both carbs had double banjo’s that the second outlet on the the slave carb could run as a return line. Do you guys think that would work ok? I do not believe my fuel pressure regulator has an option for a return line.
Lo-Fi Version | Time is now: 14th May 2024 - 01:37 PM |
