Return fuel line with carbs?, Anyone running return fuel line with cabs? |
lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
gothspeed |
Feb 5 2018, 12:21 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif)
But it would depend on the type and range of regulator. Second choice would be option D with a Y feeding carbs. |
bbrock |
Feb 5 2018, 08:27 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif) But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs. To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right? |
gothspeed |
Feb 5 2018, 08:42 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif) But it would depend on the type and range of regulator. Second choice would be option D with a Y feeding carbs. To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right? Yes, there are regulators that 'send out' a regulated target pressure (inline) and some that 'bleed out' anything over your target pressure (return). (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 06:41 PM |
