Return fuel line with carbs?, Anyone running return fuel line with cabs? |
lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
gothspeed |
Feb 5 2018, 12:21 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif)
But it would depend on the type and range of regulator. Second choice would be option D with a Y feeding carbs. |
bbrock |
Feb 5 2018, 08:27 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif) But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs. To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right? |
ChrisFoley |
Feb 5 2018, 08:46 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif) But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs. To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right? Yes, except that in option B the upstream regulator is useless. A blocking regulator is needed downstream. We had a 914 here recently which came with a single carb that had an internal regulator. It needed the return line to work. Otherwise I don't think I've ever seen a 914 with a carb setup in my shop (other than stock 914-6) that used a return line. |
bbrock |
Feb 5 2018, 10:22 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif) But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs. To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right? Yes, except that in option B the upstream regulator is useless. A blocking regulator is needed downstream. We had a 914 here recently which came with a single carb that had an internal regulator. It needed the return line to work. Otherwise I don't think I've ever seen a 914 with a carb setup in my shop (other than stock 914-6) that used a return line. And that answers my next question about option B (IMG:style_emoticons/default/biggrin.gif) I'm planning to run a return line on my carbed /4. I might want to switch back to FI in the future so it seems like a good way to future-proof the setup. Plus, I like the idea of a return line anyway. |
Lo-Fi Version | Time is now: 14th May 2024 - 12:38 AM |
