Return fuel line with carbs?, Anyone running return fuel line with cabs? |
lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
rhodyguy |
Feb 21 2018, 12:53 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Get the self regulated carter pump. Keep it simple. Put the return line in the tunnel while you're in there so it's ready if you go back to fi. Cap both ends, the return spigot on the tank and leave it alone. Single supply to a Tee in the engine compartment. One line to each carb. Keep the carb lines off of the engine tin. Stock phenolic spacers under the intakes help with the heat. Some expensive hp pump, a gauge and regulator?
Lo-Fi Version | Time is now: 13th May 2024 - 09:30 PM |
