Front trunk release with pull and guide tube $99 shipped domestic, $30 core so ($69 if you send yours back) |
Mikey914 |
Feb 5 2018, 03:11 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I got a bunch of the front trunk release mechanisms re plated and I'm offering up as a replacement set at $99.
I am missing the cable retaining clips so if you do exchange DO KEEP THE ONES ON YOURS Included are - 1 front trunk mechanism replated 1 trunk cable 1 trunk tube for cable Clip not included (see pic) I have 7 of these ready. Attached thumbnail(s) Attached image(s) |
bdstone914 |
Feb 5 2018, 08:27 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
There are two versions of lower front latches. You show the type with two springs. Other type has one spring. They are interchangable. Some owners will want the original type back on the car.
Attached thumbnail(s) |
Mikey914 |
Feb 6 2018, 01:52 AM
I do have both, so specify if you care.
Thx |
BuddyV |
Feb 7 2018, 01:00 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
Mikey -
I have been putting off ordering a new cable..... i the new latch for people looking to improve the look of the exposed latch? They don't fail, do they? Usually it's just the cable? Just wondering (because now I am wondering what parts I need to do my repair) (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Feb 7 2018, 01:07 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mikey914 |
Feb 8 2018, 01:33 AM
The release mechanism I've never heard of a failure. the do get all gummed up with crud, but the springs do the heavy lifting, and short of a spring failure I'd say pretty bulletproof.
Typical failure modes of the entire unit are 1- The cable 2- The plastic tube becomes cracked in multiple locations and actually flexes when pulled. Symptom is it requires more "pull" over time. Also do note, you want to route the plastic cover exactly like the factory as it has hold downs to allow it to guide the cable. Otherwise it will not have proper tension. |
Lo-Fi Version | Time is now: 6th May 2024 - 07:15 PM |
