Note to admin(s), Error in info section. |
mihai914 |
Jun 1 2005, 08:18 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Just a note, in the infos section more specifically in the Body Dimensions section, some of the measures are erronated, for example X which is the diagonal distance from roll bar to roof is stated as 1997mm and it should be 1337mm, same thing for the letter m which is the distance across the windshiel frame 1711 vs. 1171mm. There may be others but I didn't check them all. Just passing along the note as this info will get more and more important with time or rust shoul I say! Thanks
Lo-Fi Version | Time is now: 19th May 2024 - 05:42 AM |
