Just a note, in the infos section more specifically in the
Body Dimensions section, some of the measures are erronated, for example X which is the diagonal distance from roll bar to roof is stated as 1997mm and it should be 1337mm, same thing for the letter m which is the distance across the windshiel frame 1711 vs. 1171mm. There may be others but I didn't check them all. Just passing along the note as this info will get more and more important with time or rust shoul I say! Thanks
