Hyd. clutch brackets |
dwillouby |
Feb 9 2018, 09:27 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Hello,
Reworking my previous post. I am selling kits to assist in converting the cable operated clutch to a hydraulic system. Kit includes the mounting plates for the master cylinder and slave cylinder, mounting hardware, parts list, and installation guide. $56.00 shipped USA PayPal to dWillouby@aol.com Thanks David |
timothy_nd28 |
Feb 23 2021, 05:40 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
The picture was just an illustration for the curly hydraulic line. I have a relatively stock 914 that has a 901. I have a 2nd project 914 which will be a LS4 and a boxster trans. So in total, I would need 1.5 kits (IMG:style_emoticons/default/biggrin.gif)
ClayPerrine |
Feb 24 2021, 08:18 AM
Life's been good to me so far..... Group: Admin Posts: 15,485 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The picture was just an illustration for the curly hydraulic line. I have a relatively stock 914 that has a 901. I have a 2nd project 914 which will be a LS4 and a boxster trans. So in total, I would need 1.5 kits (IMG:style_emoticons/default/biggrin.gif) Timothy, When I put the Cayman trans in my car, I ran a hard line to the left rear corner of the engine compartment where I added a brake line bracket from a bent front strut. Then I used a 356 rubber brake line hose to run from the body to the transmission. It is the right length and readily available. And you have to get the right sized master cylinder to make it work with a Boxster/Cayman trans. I ended up with a Wilwood master cylinder. The stock 964 master cylinder was too small to move enough fluid for the Cayman clutch. Good luck. |
Lo-Fi Version | Time is now: 27th May 2024 - 06:24 AM |
