Would you buy this?, 2.0l for $200 canadian |
redbaron |
Jun 2 2005, 08:37 AM
Newbie Group: Members Posts: 31 Joined: 9-February 05 From: Alberta, Canada Member No.: 3,583 |
Complete 2.0 motor with fan housing, injection, tin, throttle body, coil, distributor etc. etc.
Problem is I don't have much time with it maybe just a leak down test then my decision. What would you do in a few minutes to get an almost informed opinion of the motor. Seller has had it in his garage and after a few years is selling, says it ran well before it came out. it was going into a van and now that project is dead. I will turn it over with a pry bar, then do a leak down, any other ideas. I think $200 canadian dollars is reasonable even if it didn't run, however it means more parts in the yard that I have to explain to the wife. More likely to fly with her if the thing did run. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
