Type 4 rear main seal: which kind doesn't leak as much? |
98101 |
Feb 11 2018, 04:59 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I'm finding contradictory information online about which kind of rear main seal I should use when we go in to fix the oil leaks. VW, Sabo? We'll be swapping the transaxle anyway, and investigating the clutch slipping. Are there any new findings about which kind doesn't leak oil?
I guess this should be called "engine to flywheel" seal instead of "rear" since it would face the front on a VW bus. |
Montreal914 |
Jan 23 2023, 01:24 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Is the seal you got from LN the Sabo as discussed above? (IMG:style_emoticons/default/confused24.gif)
DRPHIL914 |
Jan 23 2023, 01:51 PM
Dr. Phil Group: Members Posts: 5,759 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Is the seal you got from LN the Sabo as discussed above? (IMG:style_emoticons/default/confused24.gif) No, LN carries VR. Pretty sure i put in the 12mm seal in this motor when i did it just 9 months ago. I will verify all when i pull it this weekend, but it might just be the galley plug or it could be leaking from the seal/case interface, will see what it looks like when i pull the flywheel. Still searching for a Sabo if i can find one . I just ordered an Ehrling from Pelican just in case. |
Lo-Fi Version | Time is now: 27th April 2024 - 05:22 AM |
