Chrome powder coat, For turn signal housings |
daytona |
Feb 11 2018, 07:15 PM
daytona Group: Members Posts: 435 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi guys,
I have some front turn signal housings that the internal finish is gone. Were they originally chromed like a headlight reflector? I was thinking of having them powder coated chrome. Any comments or suggestions? Or should I just leave them as is? Thanks, Bill. |
Feb 11 2018, 07:32 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy new chrome ones at 914rubber. Sell your old ones.
Tom_T |
Feb 11 2018, 07:49 PM
Hi guys, I have some front turn signal housings that the internal finish is gone. Were they originally chromed like a headlight reflector? I was thinking of having them powder coated chrome. Any comments or suggestions? Or should I just leave them as is? Thanks, Bill. Bill, Yes, they were originally chrome inside the bucket only. If you don't want to fork out for new repro's from 914Rubber, then there are 2 home project or local shop alternatives .... PC - I don't know if that pot metal will hold enough of a charge to work for powder coating, check with your PC guy, or use a home/hobbyist PC kit. PC works best if you can batch multiple items. Paint - Others on here have also had good luck with a good quality rattle-can chrome paint, but if you have to clear coat it, then use gloss clear & test first clear-over-chrome paint on some paper or other scrap. Sometimes clear will dull the chrome paints. IIRC there are topics on here by members who have done both PC & paint successfully on these & other shiny 914 bits, but you'll do better to use google search to find them, since the search function on here doesn't work as well. If you do paint yourself, then you may want to do your taillight buckets at the same time, if they need a freshening up too. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
bdstone914 |
Feb 11 2018, 07:50 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi guys, I have some front turn signal housings that the internal finish is gone. Were they originally chromed like a headlight reflector? I was thinking of having them powder coated chrome. Any comments or suggestions? Or should I just leave them as is? Thanks, Bill. I don't think 914 rubber is making turn signal buckets. They are made of zinc and it does not Powder coat well. It emits gases and bubbles the paint. I would also be concerned with damage from the heat. I use silver metallic paint. With the lens on you can not tell the difference. |
ConeDodger |
Feb 12 2018, 12:51 AM
Apex killer! Group: Members Posts: 23,577 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Big deep secret. Powder coating is just melted powdered paint. Paint them. (IMG:style_emoticons/default/evilgrin.gif)
Feb 12 2018, 12:59 AM
Big deep secret. Powder coating is just melted powdered paint. Paint them. (IMG:style_emoticons/default/evilgrin.gif) It's melted polyester or epoxy powder. |
914Sixer |
Feb 12 2018, 02:05 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Several different paint options. Another option is to find some one that does liquid chrome applications. Not cheap but way cool.
gothspeed |
Feb 12 2018, 02:07 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I don't think 914 rubber is making turn signal buckets. They are made of zinc and it does not Powder coat well. It emits gases and bubbles the paint. I would also be concerned with damage from the heat. I use silver metallic paint. With the lens on you can not tell the difference. This is what I am going to do, turn signal and tail lights ^^^ (IMG:style_emoticons/default/smile.gif) |
clapeza |
Feb 12 2018, 02:57 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Do you want to keep it original, or do you want to be seen?
If it's the latter, check out: https://www.spokeworksled.com/914-led-solutions Great products and a member here. |
daytona |
Feb 12 2018, 07:17 PM
I am not ready for the LED lights just yet, but I do want to improve the lighting situation.
Improving the reflectivity inside the turn signal housing should help. I think I am going with the painting and going to forego the powder coating. Thanks for all the comments. I had not considered that the heat of the powder coating ovens were too hot for the pot metal. Thanks to all. Bill. |
Feb 12 2018, 07:27 PM
I misread the first post. I was the nkung fog light grill. I did not think you could ever powdercoat the turn signal. It has a plastic base at the wire contacts. We fire up the oven to 400 to bake the powder.
I have a bunch of Spokes led lights. They are much brighter than stock. Great investment. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:36 PM |
