My High Amp Alternator, how I did it, and you can too |
McMark |
Feb 12 2018, 11:58 AM
My original thread with real pictures
I won't be making/adapting these anymore, so I wanted to share all the info I found. I used the MechMan Alternators 150amp (Part Number: 7771150) but it's been discontinued. It's listed for a 1991 Ford F-150 5.0L motors. There are two different alternators with the same body (pictured below), the wrong one has the connector at 2:00 and the RIGHT one has the connector at 10:00. There are other options, but if I were doing another one, I would order the Bosch AL562X which is a 75A unit. There are aftermarket builders who make these up to 220A. Adaptation should be similar for all. The image below should hit most of the major points, but here's a few extra details: *If I were doing more of these, I would look into just making an alternate version of the upper and lower brackets to work with an unmodified Ford alternator. That way if you need one while away from home, it's possible. *The unit I bought had an internal fan, the stock Ford units use a front mounted fan. If anyone tries this they'll have to confirm that the fan + pulley still line up with the fan pulley. Visually, it appears that the internal or external fan setup occupies the same space (compared to each other) but the internal just has extra material in the case to encapsulate the fan. So I suspect the fan will be a non-issue. *These Ford alternators also use a ribbed belt, so a V-Groove belt would need to be sourced. I looked quickly on eBay and it appears that they should be pretty easy to come by. *Offset drilling the upper hole is almost impossible to do freehand. You'd need to take it to a machine shop. I built a drill jig to keep my drill bit in the right place. The difficulty of this step is another reason why I'd recommend someone design new brackets -- you wouldn't need to drill this out and could simply loosen/tighten the upper bold 'from the back'. I'd be happy to loan out my drill jig. It worked for me and it should work on these, but I can't guarantee the location is perfect on all variations of this alternator. And finally, when grinding/milling/cutting on the alternator body make sure to tape off any holes where bits of metal could enter the alternator. Attached image(s) |
malcolm2 |
Feb 15 2018, 08:56 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Front looks exactly like our 50amp model. The back has a built in cooling tube and similar if not the same electrical connection. What I would really like to see is a dimension drawing. Can't find one of those for our 50amp model either.
Boomingbeetle |
Feb 22 2018, 11:28 PM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
Front looks exactly like our 50amp model. The back has a built in cooling tube and similar if not the same electrical connection. What I would really like to see is a dimension drawing. Can't find one of those for our 50amp model either. I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo |
malcolm2 |
Feb 23 2018, 07:08 AM
I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo Let me ask you a couple questions then.... Did you use the cooling air elbow for the 914 or a VW bus? Did you use the pulley with a fan on it.... also from the VW bus? Did you have an issues with the belt lining up? |
gothspeed |
Feb 23 2018, 12:17 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I can confirm that this unit is a direct fit, I installed one last year. No issues powering my HID headlamps and stereo Let me ask you a couple questions then.... Did you use the cooling air elbow for the 914 or a VW bus? Did you use the pulley with a fan on it.... also from the VW bus? Did you have an issues with the belt lining up? +1 ... I would like to know the above as well (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 07:06 AM |
