My 7mm Caliper bolt solution |
n2j2ryan |
Feb 12 2018, 10:14 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
After many suggestions and a visit to a machine shop, I decided with this solution. I tapped out one end from the 7mm hole to a an 8mm thread. The other end I just bored out to 8mm. It now takes an 8mm socket head bolt, without a nut, just like the later callipers. Total cost of all bolts $12, instead of the $16 per bolt plus delivery from the UK.
gothspeed |
Feb 13 2018, 02:37 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This makes a lot of sense as the 7mm bolt holes are on the sloppy side. If you ream the holes to barely accommodate 8mm bolts, the assembly will be plenty strong. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 7th May 2024 - 10:48 AM |
