1911 |
1911 |
stewie |
Feb 13 2018, 01:07 PM
Newbie Group: Members Posts: 8 Joined: 11-February 18 From: seattle, wa Member No.: 21,883 Region Association: Pacific Northwest |
What is the cheapest combination to get a 1911 out of a 1.7 stock everything?
Here is what i have in mind.. 94mm pistons and cylinders.. I've heard 94mm is barely adequate so 96 might be a stretch... stock cam 1.7 heads bored out to the OD register of a 1.8/2.0 Stock crank stock rods dual empi 34 carbs Any other combination that is cheaper and more efficient? |
Alphaogre |
Feb 14 2018, 03:47 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
When I got my 914, it came with a 1.7 and dual Webber 44's. I drove it for a while and then I had a piston go bad, so I did the short stroke 1911 built. Larger pistons stock stroke, stock cam machined 1.7 heads. It was better, little more grunt and torque than the origin old 1.7 motor...
I then had a rod bearing go bad due to an oil flow blockage... since we now had to split the case I ordered a custom cam, and added a conically shaped oil pressure release valve and the tuna can... The difference between the short stroke 1911 motor with a cam and doing it without the cam is a BIG difference. The difference between the motor now and the stock 1.7 is night and day...not even close to the same car. I think when I broke down the math I could have just spent $600 more during the first build, and gotten to my current set up much faster. I always tell people, there are few things that years down the road, everytime you drive it, you will still say "worth every penny", the cam is one of those things... |
Lo-Fi Version | Time is now: 19th May 2024 - 02:08 AM |
