1911 |
1911 |
stewie |
Feb 13 2018, 01:07 PM
Newbie Group: Members Posts: 8 Joined: 11-February 18 From: seattle, wa Member No.: 21,883 Region Association: Pacific Northwest |
What is the cheapest combination to get a 1911 out of a 1.7 stock everything?
Here is what i have in mind.. 94mm pistons and cylinders.. I've heard 94mm is barely adequate so 96 might be a stretch... stock cam 1.7 heads bored out to the OD register of a 1.8/2.0 Stock crank stock rods dual empi 34 carbs Any other combination that is cheaper and more efficient? |
jcd914 |
Feb 13 2018, 02:14 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If you want a 1911 you have to use 96mm pistons.
With 94 pistons you are only building an 1832. If you are using carbs why use a stock cam. I would be using FI but I have FI parts. Good luck with your build, share what you choose to do. Jim |
Lo-Fi Version | Time is now: 6th May 2024 - 11:12 AM |
