1st Drive in my SIX, Just what I needed |
redshift |
Jun 2 2005, 05:57 PM
JP got black flagged for destroying the Panther team.
(indy joke.. either you get it or..) M |
Mr Dick |
Jun 2 2005, 06:01 PM
Off on another exiting adventure with the kid Group: Members Posts: 24 Joined: 23-March 05 From: Garland TX Member No.: 3,802 |
URY914 |
Jun 2 2005, 07:12 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,273 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The folks at the airpost are paving the taxi strip that we use. We have our fingers crossed that they are going to pave the entire width of it. If not we got a big ass hump to drive over. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Paul |
michel richard |
Jun 2 2005, 07:41 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
We absolutely need all the details !
Which pistons and cylinders ? What compression ratio ? Induction details ? detail on the carbs etc . . . Head details: port and valve sizes Which cam? Air filter ? Exhaust (although we can see some of it ) ? Crankshaft ? counterwheighted (sp?) or not ? tranny ? Rods ? How is twin plug done ? Which engine cases ? The reason being: I have a 2.2 E MFI in my car, counterweighted crank and 5R case. I also have steel flares waiting to be welded on, and a short stroke 2.5 is an engine I've been seriously thinking about. Fabulous that you've achieved this ! Michel Richard |
carr914 |
Jun 3 2005, 05:42 AM
Racer from Birth Group: Members Posts: 118,258 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Michel & friends
Started as a 2.7 7R case, case machined to accept 90 mm cylinders and shuffle pinned, Custommade JE pistons, compression ratio is 10.5 to 1, rebuilt & modified early Webers with 36 mm venturis on new 40/36 PMO manifolds with K&N filters and water shields, port work done on heads with new ss valves and hi-perf springs( I don't have the valve sizes infront of me, but will find out) Custom hand ground cams .412/.390, used a 2.2 crank that was cross drilled for oiling, twin-plug work (all machine work done by JB Racing- Tavares, FL right next door to Alex Job Racing), 3.0 SC oil pump, Electomotive Crankfire igntion, Motor dynoed at JBR with 220 hp and 185 ft/lbs torque, Kerry Hunter headers with megaphones from GT racing, 901 tranny rebuilt with short gearing by Brad Mayeur, Factory lightweight 906 flywheel, 911S clutch, Big front oil cooler from a 944 GTR with -16 ss lines. 89 Carrera calipers & disks with Pagid Orange pads, Rear coil over set-up, front RSR struts both with Koni Sport Yellows, 8x15 fronts & 9x15 rears Fuchs polished. T.C. Attached image(s) |
carr914 |
Jun 3 2005, 03:18 PM
Boy, I would really like to thank all those that congratulated me on this project. It was ALMOST as good as that 1st drive. ALMOST, cause nothing beats driving my teener. Thanks everybody, you guys are the best.
(IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) T.C. |
Gint |
Jun 3 2005, 06:00 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Nice goin!
I can't wait to start mine up again after it's long rest(o). |
carr914 |
Jun 5 2005, 10:57 AM
Took some more pix.
Front Shot Attached image(s) |
carr914 |
Jun 5 2005, 11:00 AM
Getty Carbon fiber hood
carr914 |
Jun 5 2005, 11:04 AM
Interior shot with new Rennshift
carr914 |
Jun 5 2005, 11:07 AM
Front trunk. I can't store anything in here
carr914 |
Jun 5 2005, 11:10 AM
Rear trunk with the Coil packs for the Crankfire Dual plug setup
carr914 |
Jun 5 2005, 11:13 AM
Engine shot
carr914 |
Jun 5 2005, 11:18 AM
corner shot
carr914 |
Jun 5 2005, 11:22 AM
Side shot
Joe Bob |
Jun 5 2005, 11:23 AM
Looks gud...congrats (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
Eddie Williams |
Jun 5 2005, 05:50 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
So what are you trying to say??? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 08:08 PM |
