Tips on removing the vent/blowers? |
Tdskip |
Feb 15 2018, 06:49 PM
It appears that these are tricky to get out. Do you remove the cables that attach to the ventilation controls in the dash, or did the dash cables come out with these?
Any been there/done that that tips to pass along? Thanks for the coaching! Attached thumbnail(s) |
aharder |
Feb 15 2018, 09:22 PM
Advanced Member Group: Members Posts: 4,375 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I had to remove the clips and separate the two and then it was still a bitch to get mine out, with fuel tank in.
SirAndy |
Feb 15 2018, 10:06 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It's much easier to remove the cables from the vents than trying to remove the other end of the cables from the controls ...
(IMG:style_emoticons/default/shades.gif) |
rhodyguy |
Feb 15 2018, 10:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,070 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Label everything. You need to buy a good penetrant and start spraying all of the connections.
burton73 |
Feb 15 2018, 10:33 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Label everything. You need to buy a good penetrant and start spraying all of the connections. (IMG:style_emoticons/default/agree.gif) Yes you pop the clip and then move the cable till the bent cable ends can feed out. Don’t cut you hand on the clips. Take it slow and yea mark everything! Bob B |
Mowog4 |
Feb 17 2018, 09:12 PM
Member Group: Members Posts: 285 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
Label everything. You need to buy a good penetrant and start spraying all of the connections. (IMG:style_emoticons/default/agree.gif) Yes you pop the clip and then move the cable till the bent cable ends can feed out. Don’t cut you hand on the clips. Take it slow and yea mark everything! Bob B I have a pretty stupid question. How does the airflow go through these pieces? Mine were missing when I got the car, now I am trying to understand it. |
Tdskip |
Feb 17 2018, 09:31 PM
Thanks gentlemen - will give this a go tomorrow.
burton73 |
Feb 17 2018, 10:13 PM
I think the air comes through the cowl and into the box and the fans push the air through the flappers that you are removing. There are connected by an air tube. I am inclosing a picture of my 6 for you to see easer on a fresh job.
Bob B |
Lo-Fi Version | Time is now: 30th April 2024 - 12:47 AM |
