Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
MarkV |
Feb 15 2018, 09:25 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
If after the event you had 30 psi at an idle I wouldn't think you damaged bearings? What was the idle pressure before the event?
SirAndy |
Feb 15 2018, 09:29 PM
If after the event you had 30 psi at an idle I wouldn't think you damaged bearings? What was the idle pressure before the event? Same as after, about ~30 at idle and ~80 under load ... (IMG:style_emoticons/default/confused24.gif) PS: Also should mention, the noise went away once the oil pressure came back up, but it sure was a loud mechanical noise like a bad bearing or a valve hitting a piston |
Lo-Fi Version | Time is now: 19th May 2024 - 05:10 PM |
