Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,666 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
Chris914n6 |
Feb 15 2018, 09:31 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
3.6L right?
Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? |
SirAndy |
Feb 15 2018, 09:32 PM
3.6L right? Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? Doh, yes, could it be that the lifters ran out of oil??? (IMG:style_emoticons/default/idea.gif) |
Chris914n6 |
Feb 16 2018, 01:22 PM
3.6L right? Hydraulic lifters? Hydraulic cam guides? What do you think the noise was? Doh, yes, could it be that the lifters ran out of oil??? (IMG:style_emoticons/default/idea.gif) Lifters are at the end of the supply chain, so it's likely what you heard. Sounds like tapping an unsharpened pencil on a desk. Doesn't explain the pressure loss though. Since it recovered I'd check for sludge buildup somewhere. Cutting the filter open is still a good idea. It will answer the bigger questions. |
Lo-Fi Version | Time is now: 30th May 2024 - 12:24 AM |
