Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,666 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
Elliot Cannon |
Feb 17 2018, 10:43 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I got one of these to cut open the oil filters on my Cessna 150 but I also use it for my car. I cut it open, slide a strong, slim magnet between the folds of the filter. I then cut out the filter paper, unfold it, take it out in the sun and check for shiny bits. If you want to borrow mine, I'll ship it up to you. http://www.aircraftspruce.com/catalog/topa...p?clickkey=4975
Lo-Fi Version | Time is now: 29th May 2024 - 11:01 PM |
